bathurst72 Offline
#1 Posted : Sunday, 18 July 2010 3:06:09 AM(UTC)
bathurst72
Hi, I have just fitted an original 10 bolt V8 tank 16.5 gallons (not a 350 tank) to my car. I have then fitted the filler.
Then I went to fit the filler neck breather and have now noticed that the tank side does not have a pipe soldered into the side to allow for the pipe to connect to. The tank has never had a pipe soldered to the side.
I know that there is a difference between HK/T and HG.
My question is there a third style of filler which has no provision for the filler breather or is it blocked off at the neck?
Any help would be appreciated.
Thanks and cheers
Steve
monro350 Offline
#2 Posted : Monday, 19 July 2010 7:15:44 AM(UTC)
monro350
Hi Steve,
The fue tank you fitted, does it have the hump for the clearance of the 10bolt, which is also on the body?
If not, its a standard 6cylinder, v8 diff.!
bathurst72 Offline
#3 Posted : Tuesday, 20 July 2010 3:31:28 AM(UTC)
bathurst72
Hi Monro350, yes it is a 10 bolt tank to fit floor hump in boot. I have been told today that I have a HK tank which has NO breather, so will have to block off breather pipe in filler neck and dummy fit to look as per HG. The other end is hidden under the boot cover.
steve
#4 Posted : Tuesday, 20 July 2010 11:02:59 PM(UTC)
If it is a HK tank then you will need to fit the other associated HK bits.
Warren
bathurst72 Offline
#5 Posted : Wednesday, 21 July 2010 3:54:58 AM(UTC)
bathurst72
Hi Warren, thanks for the reply its been nothing but a problem finding a tank and Iam happy to have a 10 bolt tank even if it is the wrong one.
again thanks and cheers
Steve
Granthk Offline
#6 Posted : Wednesday, 26 June 2013 4:53:27 AM(UTC)
Granthk
Hi, I have a hg 10 bolt 16.5 gallon tank with the breather on the right in really good condition and I need a hk 10 bolt 16.5 gallon tank with a breather on the left, I'm willing to swap if someone is interested
