#1 Posted : Tuesday, 17 August 2010 8:07:39 AM(UTC)
Hi all, I was told to join this site cause I need some info. here goes, I was told that lh- lx torana stubs and brakes will bolt on to my hr ute. any help appreciated thanks
Sam
#2 Posted : Tuesday, 17 August 2010 8:29:51 AM(UTC)
sure mate, top site, just dont have a laugh with others or say anything thats TRUE, especially about the rarity or value of a dirty old holden, cos if you do, your post will be deleted and you will be given no reason apart from the fact you you are off topic.
now, back on topic, i really dont know if LH with fit.
someone in here will know though
adam PERTH Offline
#3 Posted : Tuesday, 17 August 2010 11:12:39 AM(UTC)
adam PERTH
yeah L on R, and R on L
Tuning for Holley carbs in Perth? PM me.
rb30EJvan Offline
#4 Posted : Tuesday, 17 August 2010 8:09:00 PM(UTC)
rb30EJvan
dont forget to change your rear shoes and wheel cylinders to suit front discs
Mike81973 Offline
#5 Posted : Wednesday, 18 August 2010 1:28:38 AM(UTC)
Mike81973
Also don't forget to change to a disc brake mastercyl as the breaking pressures and residual pressure vlaves do change.
Mike
Purpul Police
Purpul Police
#6 Posted : Wednesday, 18 August 2010 1:29:03 AM(UTC)
thanks, but I dont understand why I have to change the wheel cylinders and shoes. sorry for my ignorance as I am new to this .
Thanks again for your replies
#7 Posted : Wednesday, 18 August 2010 1:33:43 AM(UTC)
hello again, so I have to change the brake master cylinder as well? do i need a booster to? or i might just get my drums all fixed up .
Any advice appreciated thanks
Sam
#8 Posted : Wednesday, 18 August 2010 1:48:24 AM(UTC)
You have to change the rear wheel cylinders because disc brakes take more pressure to work effectively than drums. Holden reduced the size of the rear wheel cylinder bores to help prevent rear wheel lockups. From memeory the smaller bore wheel cylinders were visibly different on the outside so you have to use the matching pair of shoes for the wheel cylinder.
You can get away without a booster but your brakes will be quite heavy.
You don't have to replace your master cylinder (that's the easy way out) you just have to remove the residual line pressure valve from your existing cylinder.
Vandals and graffiti "artists" do everyone a favour and target parking meters and fixed speed cameras only.
#9 Posted : Wednesday, 18 August 2010 2:49:48 AM(UTC)
ohh ok , so simlar to the hk disc to drum set up? or am I wrong again?
Sam
#10 Posted : Wednesday, 18 August 2010 3:19:31 AM(UTC)
Sam
Similar set-up yes, but the HK was larger front & rear. The HD/HR have 254mm front disc rotors & 9-inch rear drums. The HK/T/G got 270mm rotors & 10-inch drums.
#11 Posted : Wednesday, 18 August 2010 3:37:46 AM(UTC)
ok so if i put a hk diff in the ute and use all the brakes off the hk it will work?
thanks again
Sam
#12 Posted : Wednesday, 18 August 2010 3:40:03 AM(UTC)
oh yeh the hk diff will be wider??
sorry again
Sam
#13 Posted : Wednesday, 18 August 2010 5:00:50 AM(UTC)
Just a quick note the Torana stubs will bolt on but they have a different KPI compared to HR stubs.
because of this it will cause you a few wheel alignment dramas.
As in not enough adjustment room available between the upper control arm and the front subframe to overcome the KPI difference.
HR ones are unique to HD/HR, you can fit LH etc rotors and calipers to the HR stubs.
But at least with the PBR calipers shown here
http://gallery.oldho...G_0007.jpg.html
you end up with a clearance problem on full lock and under certain suspension conditions. (they hit on the lower control arm and lock the wheel up.)
Cheers Paul.
#14 Posted : Thursday, 19 August 2010 3:25:27 AM(UTC)
Hi again, reading all these posts make it nearly to much work and money to bother with doing.
A mate has a very rusty hk roller i can get for $300 if i take all the brakes etc off it, will they all bolt up and work (assuming they all work) it also has a booster , will that bolt up to the HR firewall?
Thanks again in Advance
Sam
rb30EJvan Offline
#15 Posted : Thursday, 19 August 2010 4:01:50 AM(UTC)
rb30EJvan
dont bother, go buy a set of hr stub axles and calipers stick with what you know works all the new parts you will need are avalible from repco ie; wheel bearings caliper rebuild kits and brake pads. i had a ute that i put discs on it did run it with out a booster for a while and the pedal is quite hard i would recamend useing a booster (vh40)these boosters are remote mounted so they dont mount to the firwall
good luck
#16 Posted : Thursday, 19 August 2010 7:05:45 AM(UTC)
where do i buy new disc brake stubs from?
thanks again
Sam
rb30EJvan Offline
#17 Posted : Thursday, 19 August 2010 6:59:42 PM(UTC)
rb30EJvan
you want buy new stub axles or calipers youll have to get them second hand (ebay is your best bet)
Utility8 Offline
#18 Posted : Thursday, 19 August 2010 9:09:00 PM(UTC)
Utility8
Gauging from some of the questions & answers posted on this particular thread, if you're considering doing the disc brake upgrade, it might be time to speak directly to a brake mechanic to do the work for you.
If you get it wrong, the "costs" can be very high.
Utility8
utility8
#19 Posted : Thursday, 19 August 2010 9:48:42 PM(UTC)
call greg @ classic oz wreck on 0249594546 he will have what you need and be able to help
my story; http://www.youtube.com/watch?v=RNc45FTenhg
This page was generated in 0.088 seconds.
