stephenreed Offline
#1 Posted : Thursday, 19 August 2010 8:23:16 PM(UTC)
stephenreed
I'm looking at buying a 750 Mighty Demon for my 355 stroker, there are two models i am looking at, P/N 5402010GC and 5402020GC, one has ANNULAR BOOSTER and the other is DOWNLEG BOOSTER. I sort of have my head around what the difference is but not sure what one to go with.
My set up is 355 stroker, 10.5:1 Comp. Crane 286 cam. VN heads flowed to 600hp. Dual plane manifold. Turbo 400. 3.08 Salisbury LSD. I'm looking around 350-400hp from the engine.
Can someone shed some light on what carby would suit my application and why.
**CHOPP3R**
71 HQ TONNER
01 WH STATESMAN
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
greenhj Offline
#2 Posted : Tuesday, 24 August 2010 1:18:14 AM(UTC)
greenhj
the annular booster will make low speed/low load driving on the mains easier, but cost some airflow over a standard downleg.
BUT, with a dual plane manifold the carb is "smaller" to the engine anyway so it should signal better, being thats the case id probably use the standard downleg booster and get it tuned by someone who knows more than main jet changes.
most of the time, with a big carb on a small engine (remember VE, not capacity is what determines this) youll be driving around on the transition slots anyway (because the engine just wont want any more air at typical road speeds), and 90% of the tuning is idle/transition. Mains are easy and all that the typical dyno monkey will bother looking at.
I also reckon teh heads are too big for that little camshaft and it will be doughy at low rpm.
you can cover the lack of airspeed with more convertor or rear gear.
3.08 gears will strangle it, no sense making more power higher in teh rpm band, then killing off throttle response with tall gears, id use 3.55 at a minimum, youll waste more fuel running an engine out of its efficiency range than youll save by deliberately undergearing it.
what are the flow numbers for the heads, who built the donk, what else do you know about it?
should be a nice street engine, what are you doing for a fuel system and exhaust?
what are you doing for convertor? Im about to take out and sell mine (I need 4500 stall minimum nowadays), and i reckon it would suit your combo well.
11.38@117mph
will go quicker
Edited by user Tuesday, 24 August 2010 1:25:12 AM(UTC)  | Reason: Not specified
stephenreed Offline
#3 Posted : Tuesday, 24 August 2010 7:10:30 PM(UTC)
stephenreed
They are only rough specs. I'm looking at a bigger cam (because of valve springs cant go any higher then 580deg lift. I've decided on the down leg carb, with single plane harrop manifold. At present the diff is stock 10 bolt LSD, will be looking at 3.55 gears.
Pacemaker headers, single 3inch exhaust.
Not sure on fuel system yet. As for the head flow numbers i have to get them checked as i bought the heads of a mate (Barbados Green VL, featured on cover of latest street machine commodores mag) and he has forgot what the figures were.
As for the converter i was thinking around 3000 - 3500???
Thanks for your help, I'm pretty amature when it comes to engine stuff. This is my first real engine build, all my mates have crazy burnout machines as mentioned before but id never really had much interest in building one myself until now, and i have moved interstate so my mates ain't always on hand for advice.
**CHOPP3R**
71 HQ TONNER
01 WH STATESMAN
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
greenhj Offline
#4 Posted : Wednesday, 25 August 2010 3:47:42 AM(UTC)
greenhj
good choice on the harrop/dl booster combo.
.580" lift is a decent stick in a flat tappet (for a streeter anyway), im only moving the valve .550ish to run the below numbers, with a "worse" manifold and 10.8:1 comp
a crane 280 is a good choice for a reasonablly comfortable driver with a good bit of poke, should be able to make 450hp easy as p1ss.
Dunno what sort of dollars you want to spend on a convertor (new/SH etc) but expect to spend 800 plus for a GOOD brand new convertor, or around 400ish for a GOOD secondhand one around 3500stall.
i wouldnt go any less than 3500 though whatever you end up doing, heavy cars love it, and people who talk about "big" convertors being a pig on the street obviously dont own one, or had one 20yrs ago when gemini convertors in turbo gearboxes was the hot ticket.
slip aint stall, remember that lol.
ll sell you mine if your keen lol, 3500 eliminator by autoflite engineering(flashes to 4k in my car) 10" shell, happy to cruise on 2500rpm, but id want 500 for it.
11.38@117mph
will go quicker
11.34@121mph
went quicker and faster, just not quick enough.
stephenreed Offline
#5 Posted : Tuesday, 31 August 2010 1:27:42 AM(UTC)
stephenreed
Hey mate, keen on your stally, Quote "around 400ish for a GOOD secondhand one around 3500stall". Where abouts are you located so i can roughly figure out postage cost and will you take $450 for it. Cheers
Stephen 0409243594
Also ordered my cam, went with the CAMTECH 248-664, found out i could go up to .600 thou lift so went for the biggest cam i could.
Thanks for the advice/help.
**CHOPP3R**
71 HQ TONNER
01 WH STATESMAN
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
greenhj Offline
#6 Posted : Tuesday, 31 August 2010 6:46:40 AM(UTC)
greenhj
good choice on the cam, make sure you get the lifters from camtech with edge orifice oiling and the lobe oiler holes too.
ive copied your number so you can delete it from your post (avoid the pranksters lol)
use 3175 as a postcode for freight and it will be close enough.
let me think about 450, im a procrastinator so if you dont here from me via text or phone post in this thread again to remind me.
engine came out on the weekend so the convertor is sitting on the bench at the moment.
11.38@117mph
will go quicker
11.34@121mph
Edited by user Tuesday, 31 August 2010 6:53:45 AM(UTC)  | Reason: Not specified
stephenreed Offline
#7 Posted : Tuesday, 31 August 2010 9:14:32 PM(UTC)
stephenreed
Yeah no drama mate, no hurry, let us know when your ready.
Yep got the edge orifice lifters too.
**CHOPP3R**
71 HQ TONNER
01 WH STATESMAN
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
greenhj Offline
#8 Posted : Thursday, 2 September 2010 3:54:18 AM(UTC)
greenhj
looks like the convertor has been sold, a friend of mine wants it, sorry about that mate but im sure something will come up if you dont intend on having a specific convertor made to your combo.
some questions to ask the seller:
What engine/trans/diff combo?
was it raced, can i see a timeslip?
Who built it, and can i have the part number?
first question will tell you a little about how it will perform in your car, obviously a 3500 convertor for a 383 will perform a lot different to the same convertor behind a 308.
timeslip tells you if the thing actually transfers power efficiently, if you get told it was behind a 500hp engine and the car 60' time is 2.0 on slicks, give it a miss.
if you can get a part number, often if you ring the manufacturer they can probably tell you whether it will be suitable, or a complete dog, on your engine.
There is scope to alter a convertor thats already been built and the only person who'll know is the guy who built it.
hope this helps in your search.
phill
11.38@117mph
will go quicker
11.34@121mph
Edited by user Thursday, 2 September 2010 3:55:33 AM(UTC)  | Reason: Not specified
