Goodo Offline
#1 Posted : Thursday, 19 August 2010 8:23:47 PM(UTC)
Goodo
What will I need to do to get 289 rego in xp that had 170.
Edited by user Thursday, 19 August 2010 8:47:29 PM(UTC)  | Reason: Not specified
Paul351xb Offline
#2 Posted : Thursday, 19 August 2010 8:43:02 PM(UTC)
Paul351xb
What State are you in?
Support female jelly wrestling. We can stop men going to war and solve world hunger all at the same time.
The Yeti Offline
#3 Posted : Thursday, 19 August 2010 10:48:49 PM(UTC)
The Yeti
Go to the RTA website, there is a forumlar for this, I think a 289 should be OK
but considering the current climate perhaps consult an Engineer. the other thing to consider is for and engine swap you will need to modify the brakes, diff etc. under the proposed new scheme this will be classed as more than 3 major modifications and could be liable to come under the new porposed ICV laws (you dont want to go there if you can avoid it)
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
www.earlyfalcons.com Offline
#4 Posted : Friday, 20 August 2010 4:07:11 AM(UTC)
Hi Goodo, talk to an engineer first, they all have differen't requirements even when they are in the same state. You basically need to have boosted front disc brakes> some will say also:
lasp/sash seatbelts in all four corners
collapsible seering column
brake failure warning light etc
Send me an e-mail and I can help you out more with the parts needed and contact info on engineers.
Deon
[email protected]
