#1 Posted : Saturday, 19 March 2005 10:12:58 PM(UTC)
Hi again,
I was wondering if all the HQ HJ HZ Holden model sedans had the same rear track and wheel arch width. Did all the premiers come standard with a v8 and I think some of the premiers had rear disc brakes, did they use the same hand brake cable setup as the utes.Thanks Owen.
#2 Posted : Saturday, 19 March 2005 10:56:22 PM(UTC)
From my knowlegde the HQ & HJ have the same basic body. Parts can swap back and forward. The HX and HZ differ somehow. I dont know for sure, as all I worry about are HQ's.
The tracking on the HQ-HJ-HX are most likely identical. The HZ changed with RTS
#3 Posted : Sunday, 20 March 2005 2:24:16 AM(UTC)
Hi Owen,
The story as I know it...
All HQ - HZ sedans had the same rear track/wheel base. The RTS cars (late HX and HZ) had a slightly different track.
In full size Holdens the HZ was the first to be released (officially anyway) with rear discs.
#4 Posted : Sunday, 20 March 2005 2:26:10 AM(UTC)
Missed a word in the above post...
The late HX and HZ cars had a slightly different FRONT Track...
Cheers...Dave
#5 Posted : Sunday, 20 March 2005 4:25:35 AM(UTC)
According to my owners manual all models hz except tonna front track 1527mm rear 1537mm tonna front 1521mm rear 1529mm with standard rims all hq-hz rear wheel arches ive measured are the same if that helps
cheers chris
#6 Posted : Sunday, 20 March 2005 7:17:31 AM(UTC)
Thanks for the replies, I was at the wreckers this afternoon checking it out to yes they are all the same width so back the the drawing board I will look at other rear ends to use. 1968 model Toyota Crowns have a rear chassis seperate to the body, I may b
Guest (5)
This page was generated in 0.107 seconds.
