#1 Posted : Tuesday, 22 March 2005 12:06:36 AM(UTC)
Hi to everyone. I am going to rebuild my red 308 engine and have heard I can put VN 5L heads straight on, but i dont wont to go full fuel injection. Can i still run a carbie and what else will need to be changed/upgraded as i am also thinking of stroking it. Thanks in Advanced. Any info Appreciated
#2 Posted : Tuesday, 22 March 2005 1:05:44 AM(UTC)
You can but you need some things to go with it. It will need new extractors, a new cam and the expensive part which is a new inlet manifold.
#3 Posted : Tuesday, 22 March 2005 2:04:13 AM(UTC)
Like J said expensive part is the manifold. Harrop make a carb manifold to suit VN but its round $600 - $700. Its the only one I have found !
Go the SANDMAN !
#4 Posted : Tuesday, 22 March 2005 2:49:40 AM(UTC)
torque-power make one as well but its the same 700 bucks as the harrop ones. Redline also make one thats a couple hundred cheaper but only available as a single plane manifold.
#5 Posted : Wednesday, 23 March 2005 4:51:11 AM(UTC)
thanks for the info and replies, now i know what to look out for. Thanks again
