andkno21 Offline
#1 Posted : Thursday, 25 November 2010 8:15:28 PM(UTC)
andkno21
I am currently restoring an EH special and would like to know if the 4 main front end to chassis rail bolts should be cad/zinc plating including the washers or should they be the engine bay colour, ie low gloss black
#2 Posted : Thursday, 25 November 2010 9:41:57 PM(UTC)
The washers are cad or zinc plated but the bolts look to have a black finish, similar to high tensile bolts.
git Offline
#3 Posted : Friday, 26 November 2010 5:46:29 PM(UTC)
git
Greetings, Don't plate these bolts as the process may weaken them. The bolts are black like an engine main bearing cap bolt whilst the attaching hardware is plated in various colours.
look out, the guru is coming through...
