NoMAD Offline
#1 Posted : Wednesday, 8 December 2010 12:46:42 AM(UTC)
NoMAD
Guys,
Chasing a HQ GTS Oil / Fuel Gauge in working condition... let me know what you have be good to have a oil reading for once
can email me at [email protected]
Nathan
Edited by user Wednesday, 8 December 2010 12:48:45 AM(UTC)  | Reason: Not specified
#2 Posted : Wednesday, 8 December 2010 1:52:40 AM(UTC)
Run a separate gauge as well if you can,its very important to get a "correct"reading.
Rhys Offline
#3 Posted : Thursday, 9 December 2010 3:42:41 AM(UTC)
Rhys
Nathan,
You'll have to specify if you want a magnetic or thermal type fuel gauge. I think it was about September 1973 when they went from magnetic to thermal gauges, and different senders.
Rhys
NoMAD Offline
#4 Posted : Friday, 10 December 2010 3:08:44 AM(UTC)
NoMAD
Rhys,
This i am unsure of is there an easy way to tell?
Nathan
Rhys Offline
#5 Posted : Friday, 10 December 2010 5:29:40 AM(UTC)
Rhys
Hi Nathan,
You can test the resistance of the fuel tank sender if you have a multimeter and know the approximate level of the tank, however if you don't have a multimeter the next best way is to test the gauge, providing it is in working condition, see below.
Remove the fuel sender wire from the back of the gauge. Make sure the 12V is still connected along with the earth strap and turn your key to ON. If the needle starts going across to full, you have a magnetic gauge, turn the key straight off to avoid damage. If it stays on empty, you have a thermal. This procedure will only work if your fuel gauge is in working condition.
Rhys
NoMAD Offline
#6 Posted : Friday, 10 December 2010 11:02:51 PM(UTC)
NoMAD
Thanks mate,
I'll give it a shot this weekend... the fuel gauge works its only the oil that doesn't
Nathan
#7 Posted : Saturday, 11 December 2010 2:14:55 AM(UTC)
Sorry ,I was talking about the oil gauge.
