#1 Posted : Wednesday, 23 March 2005 9:16:50 PM(UTC)
Hi all, will a bog stock standard manual VS commodore run without a vehicle
speed sensor connected?
I realise that the fuel cutoff on decel and the lean cruise mode will not
function, but will the engine actually run properly??
Cheers Dre
#2 Posted : Wednesday, 23 March 2005 10:04:30 PM(UTC)
They run, but not properly. Much like a VL will run with it's hot-wire air mass sensor busted. The fuel economy in most cases is crook though.
#3 Posted : Thursday, 24 March 2005 12:05:59 AM(UTC)
Thanks, but the fuel economy is only effected by the fact that the lean cruise mode (which only works above 80k/h) wont work (oh and the decel fuel cutoff, which I was planning to bypass anyway, I love the sound of the burbling when your engine braking :)
#4 Posted : Thursday, 24 March 2005 5:55:00 AM(UTC)
They also tend to want to stall on decel at low road speeds - like slowing down for red lights.
This page was generated in 0.115 seconds.
