edmundo Offline
#1 Posted : Monday, 13 December 2010 2:24:30 AM(UTC)
edmundo
My 2007 bf wagon front end shakes when i apply the brakes, it vibrates when i just touch them travelling at 60klm etc.
any thoughts?
BIGCAV Offline
#2 Posted : Monday, 13 December 2010 2:54:33 AM(UTC)
BIGCAV
warped rotors
greenhj Offline
#3 Posted : Monday, 13 December 2010 3:05:02 AM(UTC)
greenhj
yeah, the falcons are supposed to be worse than the crummydores which is really saying something.
my vz needed 3 machines on one set of (factory) rotors.
just skim 'em and put 'em back on, supposedly aftermarket stuff like DBA etc arent anywhere near as bad but the stockers are s***e.
11.38@117mph
will go quicker
11.34@121mph
went quicker and faster, just not quick enough.
now being rebuilt with less cam, much less comp, and a turbo.
Edited by user Monday, 13 December 2010 5:12:40 AM(UTC)  | Reason: Not specified
Paul351xb Offline
#4 Posted : Monday, 13 December 2010 8:11:43 AM(UTC)
Paul351xb
flick the stock rotors and get the decent aftermarket ones. Ford never did bother to get that issue right. Such a simple fix that would have had a lot less disgruntled customers.
castellan Offline
#5 Posted : Tuesday, 14 December 2010 10:39:17 PM(UTC)
castellan
I think it's just the pad material glazing on the rotors.
XB351 Offline
#6 Posted : Thursday, 16 December 2010 4:07:28 AM(UTC)
XB351
You should be able to get rotor and new pads for $200ish (front & back). I just replaced mine today for that very same reason. It's not worth machining them as the shake will come back. Spend the money on new rotors. If you fit it all yourself? Make sure you grease the slides (marine grade bearing grease is great) and clean all the rust and scale off hubs. May as well adjust your handbrake while your there too. :)
