Simmons001 Offline
#1 Posted : Saturday, 25 December 2010 7:40:40 AM(UTC)
Simmons001
Ok, here is the story
Took car (Series 1 VS Caprice V8 HSV 185kW option, 166000 kays) to Holden dealer for paint (friend runs the paint shop). They have it for a week or so. The fire it up to give it back to me and oil light on. Fair enough, it has the odd oil leak, put more oil in it. But then drive it for 10 minutes and oil light comes back on. "Oil pick up" they say. Flush flush, check oil pump, change oil, flush flush etc. Car will idle forever no problems, but drive it for a bit and up comes the oil pressure light. "Oil pick up they say, take car home and get fixed, we too expensive" Fair enough I thought, except for the fact it had no problem before it went in. But these things do happen like that.
So i save the money and drop it in to local mechanics saying "Holden say oil pick up". Fine says mechanic.
So they put the mechanical oil pressure guage on it and get 7 psi at idle, 20 with a rev, which slowly decreases as it warms up. 19, 18, 17 with a rev etc until they turn it off due to low oil pressure/oil light. There is much consultation amongst the mechanics. "Not oil pick up" they say "we ain't gonna charge you $600 to take the sump off and find out its not that, we think its shot cam/crank bearings, here is your car, let us know what you wanna do" On the plus side they charged me nothing beyond new oil & filter which was the first thing they did.
So this is where I am at. I don't know what is actually WRONG with the car beyond low oil pressure. It still could be the pick up, but I am unconvinced. Other than the engine, car is in very nice condition, new paint, interior is excellent, new brakes, new tyres (yes, i had been spending some money and I baby the damn thing) everything works and is original blah blah.
So is it cam/crank bearings? Is it possible it is the oil pump or faulty oil pump bypass? And if it the bearings do I
a) buy a V8 from a wrecker and bung it in.
b) buy a reco V8, swap the bolt ons to make it 185kW again
c) rebuild my engine with some go faster bits (lumpier cam and 5.7 stroker)
d) wreck it and buy WL Grange.
I am torn because whilst I do love the car, do I love it enough to keep it long enough to make a new engine worth while? Bodge it and sell it? Arrgh indecison!
Over to you. Any recommendations for crate 5.0's while we are at it?
Cry Havoc! And let slip the dogs of war!
#2 Posted : Saturday, 25 December 2010 8:45:13 AM(UTC)
personally i like option c, it'll fix the problem and the upgrade in power will put a smile on your face
#3 Posted : Saturday, 25 December 2010 6:57:00 PM(UTC)
I like C ...and you should put really thick oil in it to drive it around(if its no good wont matter) ,buy the best deal v8 on ebay ,build that up,swap em, then sell the other one....just what I would do(even just the bottom end)
classic oz wreck Offline
#4 Posted : Saturday, 25 December 2010 8:39:09 PM(UTC)
classic oz wreck
a couple of years ago i had the same problem ..difference with me is i had already changed the pick up out for an early commodore one and i had owned the car for years and serviced it regularly...all the experts told me it was this or that...
turned out that it had broken one tooth off the oil pump drive gear at the end of the cam..when it was cold it was fine and once it warmed up it lost all oil pressure as the oil pump stopped turning..easy fix,you need to remove the front of the motor..first but i would change the oil pump to start with and if that does not fix it go the second bit which was my problem...btw,my 5.0 had 340,000 k on it at the time..it went to 430,000k before it died and it still had a good cam and bearings.
www.classicozwreck.com.au
#5 Posted : Saturday, 25 December 2010 10:14:34 PM(UTC)
Yeah,thinking more about it I think Greg(classic oz) is on the money with this one,change oil to a thicker viscosity
and change the oil pump and check/replace the sensor before getting further into it.
adam PERTH Offline
#6 Posted : Saturday, 25 December 2010 11:22:03 PM(UTC)
adam PERTH
i would look at oil pump.
take oil pump inspection cover off and look at gears,
if all looks good, then get a replacement High Volume one in case it is worn bearings and the HV pump will compensate for that.
do it yourself.
30 minutes job including cleaning up afterwards.
do this before looking at options a,b,c,d.
Tuning for Holley carbs in Perth? PM me.
Edited by user Saturday, 25 December 2010 11:29:07 PM(UTC)  | Reason: Not specified
Simmons001 Offline
#7 Posted : Sunday, 26 December 2010 12:35:30 AM(UTC)
Simmons001
Thanks guys, yep I will/am going to change out the oil pump.
Is it worth going for a HV or leave it as a standard? I have heard stories of HV's blowing old seals especially main seals. I am inclined to stay stock.
I was suprised at the suggestion of bearings being as above I baby the thing and change the oil plenty, especially as it has only 166k on the clock.
I will keep you informed and appreciate any further comments/advice.
Cheers all
adam PERTH Offline
#8 Posted : Sunday, 26 December 2010 7:02:09 AM(UTC)
adam PERTH
only get a HV oil pump if your oil pressure is highly variable and moves up and down with your RPM.
otherwise go STD oil pump
#9 Posted : Sunday, 26 December 2010 10:27:24 PM(UTC)
classic oz wreck
wrong...i went the high volume and it did not work any better because of my unique problem...just get a good second hand oil pump from any v8 holden as they are the same..pack it full of grease or vaso and fire it up..if that works buy a new one..if not pull the timing case cover and check for the same unique problem i had...
adam PERTH Offline
#10 Posted : Monday, 27 December 2010 5:43:49 AM(UTC)
adam PERTH
Disagree.
Classic OZ, it didn't fix your problem because it didn't have a faulty pump or worn brearings in the first place by the sounds of it.
#11 Posted : Monday, 27 December 2010 6:27:59 AM(UTC)
I had the same problem with my 253, it eventually cured itself after standing for a day or so. but you could check the oil pressure relief spring, cheap and esy to fix.
Simmons001 Offline
#12 Posted : Tuesday, 28 December 2010 6:56:38 AM(UTC)
Simmons001
Actually I was thinking it might be the oil pressure relief valve... How do i pretension the spring if it is worn?
#13 Posted : Tuesday, 28 December 2010 11:38:36 PM(UTC)
classic oz wreck
Originally posted by adam PERTH
Disagree.
yes and thats why i was saying wrong...no point forkin out for a h/v pump if that may not be the problem...maybe i should have worded it better adam..
Simmons001 Offline
#14 Posted : Thursday, 30 December 2010 9:28:01 AM(UTC)
Simmons001
Gonna pick up a JP HV pump and see how we go with that. Hopefully that will solve the problem. I am thinking oil pump or something weird myself, i don't buy shot bearings in a baby'd car at 166k
#15 Posted : Friday, 31 December 2010 7:07:59 AM(UTC)
the cam shaft people (crowe or crane can't remember but is on their site)recommend that high vol pumps not be used on street motors as the pressure washes out the bearings over a long period. they reckon even modded motors can run perfecly well with standard pump, highly modded motors for drags etc get rebuilt frequently so bearings are not a problem.
besides you might not buy shot bearings at 166k, that doesn't mean they aren't worth looking at just to be sure and maybe save some money.
Simmons001 Offline
#16 Posted : Friday, 31 December 2010 7:43:46 AM(UTC)
Simmons001
Yeah true.
Lets stick with standard.. even tho they are more expensive for some reason. :)
Simmons001 Offline
#17 Posted : Friday, 7 January 2011 3:09:04 AM(UTC)
Simmons001
Which is proving more difficult that i thought. Not only are the HV a LOT cheaper for some reason, an oil pump full stop is proving difficult to locate
Anyone got an opinion on this? JP Standard? Price seems good too. I have however read differing opinions on JP. Are there other options/recommendations?
http://cgi.ebay.com.au/H...ries&hash=item2a0cfddfaa
Edited by user Friday, 7 January 2011 3:14:25 AM(UTC)  | Reason: Not specified
This page was generated in 0.969 seconds.
