80569K Offline
#1 Posted : Sunday, 26 December 2010 5:57:36 PM(UTC)
80569K
Re HK HT HG bonnet W moulding end clips.
On another forum you responded to a question about the end clips for this moulding.
Do you have any news regarding whether the clip out of Rare Spares kit p/n BMC1003 is suitable?
It would appear that some cars have screw on end clips (HK's?) and others have the studs all the way along the bonnet edge which use the slide on clip you sell.
BIGCAV Offline
#2 Posted : Monday, 27 December 2010 12:21:00 AM(UTC)
BIGCAV
Hi
im working from memory here and wont be back in the office till wednesday, ill be at our retail store on monday so i will try and check then
i checked this moulding on a unrestored hk monaro and there was no end clip at all, no spot where a clip used to be, no stud, no screw hole, nothing ...
but it was the only car i had access to and couldnt check a ht or hg etc
i will check the clip in one of our moulds to see if its the correct width to fit the next chance i get
again from memory (im at home) the parts catalogues dont list a end clip for any model either but if they are neded in the kit i will put 2 in
BIGCAV Offline
#3 Posted : Wednesday, 29 December 2010 8:21:49 PM(UTC)
BIGCAV
80569K Offline
#4 Posted : Saturday, 8 January 2011 1:24:21 AM(UTC)
80569K
Thank you good as gold.
