#1 Posted : Thursday, 24 March 2005 8:17:03 AM(UTC)
Where is the vl fuel pressure regulator located?
Taz2 Offline
#2 Posted : Thursday, 24 March 2005 4:39:28 PM(UTC)
Taz2
Right next to the exterior fuel pump at the tank. There is a bracket that holds the pump and regulator together right above the rear axle. There is a screw on top of the regulator for adjustment.
There is another reulator at the fuel return end of the fu
In thrust we trust
#3 Posted : Friday, 25 March 2005 8:05:08 PM(UTC)
Hi Guys.
The fuel pressure regulator for the VL is mounted on the inlet manifold & plumbed into the fuel return from the fuel rail (98% of modern EFI cars are done this way).
The small device that Taz2 is referring to, is only a fuel damper. It is a
