Where is the vl fuel pressure regulator located?
Right next to the exterior fuel pump at the tank. There is a bracket that holds the pump and regulator together right above the rear axle. There is a screw on top of the regulator for adjustment. There is another reulator at the fuel return end of the fu |
In thrust we trust |
Thanks: 1 times Was thanked: 244 time(s) in 218 post(s)
Hi Guys.
The fuel pressure regulator for the VL is mounted on the inlet manifold & plumbed into the fuel return from the fuel rail (98% of modern EFI cars are done this way).
The small device that Taz2 is referring to, is only a fuel damper. It is a |
