sen57r Offline
#1 Posted : Sunday, 9 January 2011 5:35:07 AM(UTC)
sen57r
hi
could someone decipher these numbers please for me please
10/71 hq coupe
BHQ13**2S
81237QH7047**
Model:81237QR
Body:13**4-S
Trim:1826-18S
Paint:567-13121
what paint colour should this be and what does the"S" on the trim code mean? is there anyway of knowing what engine/box it should have?
i dont have any original paper work
also the number that is stamped into the firewall is different to the body no: is this normal or should they be the same it is 4 numbers different 13**8-S ?? ,,,,thankyou
JBM Offline
#2 Posted : Sunday, 9 January 2011 5:53:10 AM(UTC)
JBM
Paint is Amethyst Metallic
Trim is Flax.
Its a Monaro LS V8 coupe.
Its a Sydney body.
If the plate with the paint codes is unstamped for the engine and trans it will be the standard combo, probably 253 trimatic with a 2.78 diff.
James
#3 Posted : Sunday, 9 January 2011 6:34:42 AM(UTC)
As James says, 1826 is Amethyst metallic. 18 is Flax and S is diamond cloth inserts.
sen57r Offline
#4 Posted : Sunday, 9 January 2011 7:26:33 AM(UTC)
sen57r
thanks guys,it has been resprayed and retrimmed in different colors,
any ideas on the body numbers? it has a police number stamped in the rails as well as the matching chassis number and is registered (and has an engineers report for a chev/t400)with the police number,engineers report dates from mid 90'sand uses police number???? maybe stolen/recovered at some stage?
#5 Posted : Monday, 10 January 2011 7:20:27 AM(UTC)
Not sure why it'd have an Engineer's report for NSW with a Chev and TH400, unless it was for a 400 or bigger? Funny that it would get a Police number too if the original number is on the rails. Even if it was stolen and recovered it could be regoed with the original numbers.
sen57r Offline
#6 Posted : Tuesday, 11 January 2011 7:29:24 AM(UTC)
sen57r
the engineers report also mentions diff modifications and 9 1/2" wide rims on the rear, so i guess its mainly aimed at that, i was wondering how i would go trying to re register it on its proper chassis no: ???
#7 Posted : Tuesday, 11 January 2011 6:17:27 PM(UTC)
Is the original number crossed out (overstamped)?
sen57r Offline
#8 Posted : Wednesday, 12 January 2011 4:00:52 AM(UTC)
sen57r
no its right where it should be, the other number is stamped next to it on the outer part of the rail
#9 Posted : Wednesday, 12 January 2011 6:50:40 AM(UTC)
I'd talk to the Police and RTA and see if any history comes up against the old chassis number. If not, I can't see why you can't weld up the Police number, file it back and use the original.
sen57r Offline
#10 Posted : Wednesday, 12 January 2011 8:01:54 AM(UTC)
sen57r
thanks for the replies guys,its great to be able to get such good info
