#1 Posted : Wednesday, 19 January 2011 10:59:07 PM(UTC)
Is the original front-rear fader switch only to control a single speaker up front and a single speaker at the rear?
I'm trying to connect this thing but theres 6 wires and only three connections and I'm confused.
Any help would be appreciated
Thanx
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin)
Edited by user Wednesday, 19 January 2011 11:02:53 PM(UTC)  | Reason: Not specified
#2 Posted : Thursday, 20 January 2011 12:01:59 AM(UTC)
There are two versions of that fader, mono & stereo.
The mono unit is to suit one front & one rear speaker connected to an AM radio.
The stereo version is to suit 4 speakers (2 front, 2 rear) & a stereo unit. In the HQs case, it was to suit the Air Chief AM - cassette stereo unit, there was no FM in those days.
The mono fader has 3 terminals & the stereo has 6.
Post your e-mail address or fax number & I can send you a diagram of how to attach the 6 wires to the 3 terminals.
Edited by user Thursday, 20 January 2011 12:55:27 AM(UTC)  | Reason: Not specified
#3 Posted : Thursday, 20 January 2011 12:41:43 AM(UTC)
Thanks Dr Terry, mine is the 3 pin mono setup.
A diagram would help alot, thanks again
Edited by user Saturday, 22 January 2011 10:17:25 AM(UTC)  | Reason: Not specified
#4 Posted : Thursday, 20 January 2011 2:42:11 AM(UTC)
RigPig, did you get my e-mail ?
Hope you can read it, the scanner is not that great.
#5 Posted : Friday, 21 January 2011 9:24:17 AM(UTC)
Yeah I got it Terry thanks for your help.
Its tiny but I can see it clear enough
Thanks again
#6 Posted : Friday, 13 July 2012 12:53:05 AM(UTC)
Hi Terry. Could you send me diagrams of mono fader wiring as im baffled as well. I have pm you. Regards.
rimzimmer Offline
#7 Posted : Friday, 13 July 2012 4:50:21 AM(UTC)
rimzimmer
Where was the mono single front speaker mounted originally? and am i right in thinking the stereo set up were in the kick panels
dirty davo Offline
#8 Posted : Friday, 13 July 2012 5:37:49 PM(UTC)
dirty davo
in middle of dash up underneath against th 'speaker grille'
i have a original perfect working one out of HJ if anyone needs one
regards DD 0412109239
