mrtf Offline
#1 Posted : Friday, 21 January 2011 1:42:49 AM(UTC)
mrtf
What are the procedures for removing and installing replacing Dash Pads on an EH ?
Is there anything to be careful of ?
#2 Posted : Friday, 21 January 2011 3:48:28 AM(UTC)
The cost!..bahahah...na not really,pretty simple.
Utility8 Offline
#3 Posted : Friday, 21 January 2011 9:45:02 PM(UTC)
Utility8
The section under the speedo is held in place by spring type pins/clips. From underneath of the pad, gently pry it off. Use your finger at each end & it should pop off. The two end pieces are each held on with a screw & a similiar clip to the pad under the speedo. The glove box pad is held on with screws.
When replacing the pads with clips, simply align the clips into the holes & with your hand, firmly knock the pad home. If the clips miss the holes, the pad will sit slightly out of position.
Utility8
Edited by user Friday, 21 January 2011 9:47:29 PM(UTC)  | Reason: Not specified
utility8
adam PERTH Offline
#4 Posted : Friday, 21 January 2011 10:26:53 PM(UTC)
adam PERTH
i am fairly sure that the pad is asymetrical, and has to go a particular way up otherwise lines will not match up between the corners, glovebox etc. been fair a while since i owned an EH but..
Tuning for Holley carbs in Perth? PM me.
mrtf Offline
#5 Posted : Monday, 31 January 2011 7:14:15 AM(UTC)
mrtf
Thanks Guys installed replacement pads with no problems.
Your advise was most appreciated !
