blameyone Offline
#1 Posted : Monday, 24 January 2011 12:33:12 AM(UTC)
blameyone
A little drama. How do I get it to return or get at it to release it ? Thanks in advance...Jack
#2 Posted : Monday, 24 January 2011 3:31:49 AM(UTC)
Try tugging sharply on it a few times to see if you can release it & allow it to retract.
If that doesn't work, then you'll have to replace it with another one.
blameyone Offline
#3 Posted : Tuesday, 25 January 2011 10:08:48 AM(UTC)
blameyone
Yeah Mick thats what I 1st thought,but no.So now how much trim to remove to get at it ?...Jack
blameyone Offline
#4 Posted : Tuesday, 25 January 2011 10:13:21 AM(UTC)
blameyone
Sorry its a VY, where did I get VS from....Jack
#5 Posted : Tuesday, 25 January 2011 10:34:11 AM(UTC)
You'll need to remove the rear seat base, then the backrest on the offending side.
Then you need to remove the bolt at the bottom - holding the end of the belt to the floor, between the 2 seat sections.
Then pop the seat-belt surround trim indsert bit out of the hole in the pillar trim - pop it from the end so you don't break it.
Then pull the C-pillar trim out, and you should be able to access the pivot bolt, and the retractor wheel bolt.
Best bet is to visit a "u pull it" type of wrecker, where you can practice on a VT-VZ (they're all the same) before you let loose on your own car!
