Duzty Offline
#1 Posted : Tuesday, 25 January 2011 3:20:13 AM(UTC)
Duzty
Just wondering if anyone could give me some suggestions on what size rims i should put on my HZ wellbody ute....
i want to get weld draglites, its just for the street, has a 9" diff, just wondering what offset i can have, ive heard its 3"
and is 15x7 on the front and 15x8 on the back a good size?
#2 Posted : Tuesday, 25 January 2011 3:50:20 AM(UTC)
The trouble with using different sized rims is you cant swap your wheels from front to back. I reckon the 8's look better but it depends on what size tyre you are going to use really. I dont understand why we have suddenly started calling utes "wellbacks". They always used to be either one tonners, utes or vans. Just my pet hate.
peter_flane Offline
#3 Posted : Tuesday, 25 January 2011 3:57:58 AM(UTC)
peter_flane
Coupe-utility
I think it is a good idea to have different wheels/ tyres front and rear on a solid rear axle car.
You can have unidirectional on the rear, and asymmetrical on the front. Your spare can be a smaller size front wheel/ tyre.
Edited by user Tuesday, 25 January 2011 4:02:42 AM(UTC)  | Reason: Not specified
#4 Posted : Tuesday, 25 January 2011 6:37:31 AM(UTC)
Why wouldnt you want asymmetrical on the rear? You wouldnt swap the rears around anyway as it is bad practice to run the tyres backwards on a rotation. I am looking at it from the point of view of good handling and extended tyre life. You are then limited to no swapping tyres around at all.
I suppose if its only a cruiser it would not matter.
peter_flane Offline
#5 Posted : Tuesday, 25 January 2011 9:09:08 AM(UTC)
peter_flane
I burnout my rear tyres long before their intended tyre life. I find unidirectional rear tyres smoke better for me!
adam PERTH Offline
#6 Posted : Tuesday, 25 January 2011 11:33:40 AM(UTC)
adam PERTH
15 x7 with 235 / 60 and 3.5BS rub on HQ up front, but not on HJ-WB (different guards at front)
for rear go 15 x 8.5 with 4.5 BS and maybe 245/60/15
Tuning for Holley carbs in Perth? PM me.
Duzty Offline
#7 Posted : Tuesday, 25 January 2011 11:38:42 PM(UTC)
Duzty
cheers adz!
will send you an email!!!
Duzty Offline
#8 Posted : Thursday, 27 January 2011 11:16:19 PM(UTC)
Duzty
If im ordering these from the states, what car has the same stud pattern as a HZ?
JBM Offline
#9 Posted : Friday, 28 January 2011 2:06:50 AM(UTC)
JBM
Pontiac Rally II wheels bolt on so anything that can go on a Pontiac or Chev with a 4-3/4" PCD will fit, back space will have to suit the car.
