#1 Posted : Saturday, 29 January 2011 8:25:45 AM(UTC)
Do HQ's have the switch that says UP/ANTENNA/DOWN or the one that has a small image of an antenna on it? They both fit and they both look right for a HQ but which switch is the correct one?
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin)
#2 Posted : Saturday, 29 January 2011 5:52:50 PM(UTC)
the one with the writing on it.
#3 Posted : Saturday, 29 January 2011 9:09:28 PM(UTC)
The one with the picture, simply has a sticker over the writting, so either can be used, just remove the sticker from the later model one.
Warren
The best part about being wrong is the pleasure it brings to others.
#4 Posted : Saturday, 29 January 2011 10:01:35 PM(UTC)
Thanks guys
Premier 350 Offline
#5 Posted : Sunday, 30 January 2011 2:09:58 AM(UTC)
Premier 350
Is the same switch, differently marked also used for the power
tailgate glass?
Just wondering.
One pair of hands working does more than a thousand pairs praying.
mackv8 Offline
#6 Posted : Sunday, 30 January 2011 8:16:39 AM(UTC)
mackv8
answer is yes. HJ and up have symbols in lieu of words (also LH Torana up)
The one with the picture, simply has a sticker over the writing, so either can be used, just remove the sticker from the later model one.
Early hj yes but but late hj and on no writing under sticker.
tailgate glass?
It is possibly exactly the same construction. but has different wiring colour code and markings
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
Edited by user Sunday, 30 January 2011 8:20:08 AM(UTC)  | Reason: Not specified
Premier 350 Offline
#7 Posted : Sunday, 30 January 2011 7:08:40 PM(UTC)
Premier 350
Thanx MackaV8. Mow I know I can sleep at night!
#8 Posted : Tuesday, 1 February 2011 8:16:39 AM(UTC)
The HQ GTS sales brochure clearly shows the antenna switch on the dash with words on it, perhaps both were available at different stages.
mackv8 Offline
#9 Posted : Tuesday, 1 February 2011 9:51:34 PM(UTC)
mackv8
tailgate glass?
[quote]Originally posted by mackv8
answer is yes.
I goofed i should have put in hear the words(yes HQ have words on them)
Edited by user Tuesday, 1 February 2011 9:56:15 PM(UTC)  | Reason: Not specified
#10 Posted : Thursday, 17 February 2011 8:21:10 PM(UTC)
HQ Antenna switch..
HJ-HZ antenna switch...
I have also come across the later HJ-Z switches with the sticker & have removed the sticker to find no writing underneath, this is also the case with the defog/demist/driving lamp switch, which has had the HJ-Z demist sticker fitted, but not with the rear power tailgate switch, all of which had the HQ writing underneath.
#11 Posted : Thursday, 17 February 2011 10:05:55 PM(UTC)
I've seen a different switch around. It's the same style of rocker but has 3 positions (similar to the antenna one) but no spring return & also has a green indicator light in the lower half. It has the word DEFOG on it.
What were these fitted to & why 3 positions (2 ON & 1 OFF) ?
#12 Posted : Friday, 18 February 2011 1:22:01 AM(UTC)
HQ Defog switch, has low & High, but I have never come across one were the low actually works, the light is to let you know it's on, also these stay on even with the ignition off (been caught out once or twice). I also believe the same switch was used on the factory driving lamps for the HQ, but had aux lamps insted of defog & only switch to high position, but I've never seen one.
HQ power tail gate.
HJ-Z power tailgate, notice it's a sticker, with nothing under it. first one I've seen.
HJ-Z LH-X-UC torana Aux Lamp switch.
#13 Posted : Friday, 18 February 2011 3:35:54 AM(UTC)
I've got this one in my late 74 HQ and its a factory fitted rear demister.
