#1 Posted : Monday, 28 March 2005 3:07:08 AM(UTC)
I have a VN HSV V8. Compared with other v8s my car seems quite noisy. There is a consistent whirring/hissing(sort of) sound that one can hear in the cabin, and is very noticeable outside the car. Obviously at the front. I want to get rid of this sound, is there anything I should check at the front? I also feel there is a hole in the exhaust, is there a fail safe way to know whether there is a hole in the exhaust?
#2 Posted : Monday, 28 March 2005 3:12:34 AM(UTC)
That hissing noise your probably reffering to is the induction noise of the air being sucked into the motor, not alot you can really do about it, if there is a hole in the exhuast there will usually be a sort of poping sort of sound, depends how bug the h
#3 Posted : Monday, 28 March 2005 4:06:01 AM(UTC)
Hi Guys.
A common noise complaint on VN/VT V8s is the noise caused by the idle control motor at idle, especially cold. You can hear it coming from the air cleaner.
If the throttle body is removed & thoroughly cleaned & the base idle reset, using a s
#4 Posted : Monday, 28 March 2005 5:15:59 AM(UTC)
try to change your extactors gasket and exhuast gasket, and tighten the bolts as tight as you can. after two day check tighten all the bolts again...
i had that happen in my carby brocky 308. i thought it was the lifter sound...but my friend told me it
#5 Posted : Monday, 28 March 2005 8:11:09 AM(UTC)
has it got the original air filter box or has someone fitted a "Pod filter"?
the pod filters aloww the intake noise to escape more, not to mention decrease power output due to engine heat.
DO NOT WRITE BELOW THIS LINE
