I have a VN HSV V8. Compared with other v8s my car seems quite noisy. There is a consistent whirring/hissing(sort of) sound that one can hear in the cabin, and is very noticeable outside the car. Obviously at the front. I want to get rid of this sound, is there anything I should check at the front? I also feel there is a hole in the exhaust, is there a fail safe way to know whether there is a hole in the exhaust?
That hissing noise your probably reffering to is the induction noise of the air being sucked into the motor, not alot you can really do about it, if there is a hole in the exhuast there will usually be a sort of poping sort of sound, depends how bug the h
Hi Guys.
A common noise complaint on VN/VT V8s is the noise caused by the idle control motor at idle, especially cold. You can hear it coming from the air cleaner.
If the throttle body is removed & thoroughly cleaned & the base idle reset, using a s |
try to change your extactors gasket and exhuast gasket, and tighten the bolts as tight as you can. after two day check tighten all the bolts again...
i had that happen in my carby brocky 308. i thought it was the lifter sound...but my friend told me it
has it got the original air filter box or has someone fitted a "Pod filter"? the pod filters aloww the intake noise to escape more, not to mention decrease power output due to engine heat.
DO NOT WRITE BELOW THIS LINE
