gthr Offline
#1 Posted : Wednesday, 9 March 2011 2:58:23 AM(UTC)
gthr
Hi All,
Strange one for you - I have a vibration that I can feel through the front end of the car and lightly through the steering wheel at 80-110kmh. Steering wheel doesn't shake/rattle like a wheel alignment problem.
Bog stock HR Prem with disk front end. Only started after I replaced the brake booster which was leaking and hence had to remove wheels to bleed brakes. Fairly confident wheels are not binding on the stud posts when put back on.
I really don't know where to start - steering column, steering box, shockers, mounts...AGH!
Ideas?
Geoff
#2 Posted : Wednesday, 9 March 2011 4:07:58 AM(UTC)
Did you knock a wheel weight off? Is one of the tyres on the way out, bulge etc? if its a country car sometimes you get a heap of mud build up inside the wheel putting it out of balance.
#3 Posted : Wednesday, 9 March 2011 6:38:52 AM(UTC)
wheel balance, as wbute said the weights can fall off (you could have accidentally knocked 1 off?)
also run your hand around the tyre, it could have a bulge in it on the side wall
Premier 350 Offline
#4 Posted : Thursday, 10 March 2011 1:21:28 AM(UTC)
Premier 350
Try swappping the wheels front to back.
peter1980 Offline
#5 Posted : Saturday, 12 March 2011 12:04:26 AM(UTC)
peter1980
check to make sure that u have tightened ur wheel nuts properly as loose wheel nuts do that to a vehicle have been caught once before.
