threespeed Offline
#1 Posted : Monday, 14 March 2011 3:53:44 AM(UTC)
threespeed
I am rebuilding my 308 to a 355 stroker and would like to run my M21 gearbox behind it. I am concerned the the M21 box will not hold up with the extra HP and I would like recommendations for where to get a full rebuild, strengthened if possible. Happy to pay $$ for a good service
There is a mob offering the followng mod - Top Loader 21 MM LAY Shaft and Rings with Mitsubishi bearings good for rev range of 7400.
Would appreciate advise as I am not fimiliar with this mod, or if actually strengthens the box!!!
adam PERTH Offline
#2 Posted : Tuesday, 15 March 2011 9:07:00 AM(UTC)
adam PERTH
M21 are ok.
3 things that stuff them are:
1) Dumping the clutch (violent) in first with a tall diff / heavy car will take cogs off first gear.
2) make sure first gear is fully dis - engaged in the box before going for reverse.
3) shift with a true H pattern to make sure box is in the right gear at all times.
