vk
joel05 Offline
#1 Posted : Saturday, 26 March 2011 1:44:31 AM(UTC)
joel05
will vn discs fit onto a vk?
#2 Posted : Saturday, 26 March 2011 5:08:08 AM(UTC)
Fronts from a VN V6 are the same as VK V8 & 6 (271mm in diameter).
If the discs are from a VN V8 (289mm) they are bigger than the VK ones, and will require the matching finned calipers from the VN.
Rear discs & calipers from a VN will swap onto a factory VK DISC BRAKE diff, but not a VK drum diff unless you pull the axles & add the spacers under the bearings.
#3 Posted : Saturday, 26 March 2011 6:44:57 AM(UTC)
brake booster ,all ok? just curious mick.
#4 Posted : Saturday, 26 March 2011 8:45:16 AM(UTC)
I'm assuming he's only swapping like for like from the sound of the post.
