OldDog Offline
#1 Posted : Tuesday, 29 March 2011 8:47:31 AM(UTC)
OldDog
Evening all, trying to fit up a Holden air con unit into the ute, i have all the bits but the vacuum hoses are not connected to the control unit, its also not shown in the manuals. Does anyone have a "wiring diagram" of these hoses? I see that they are colour coded.
Thanks in advance
Bill
#2 Posted : Tuesday, 29 March 2011 5:15:06 PM(UTC)
WB parts catalogue shows it, go to a Holden dealer and see if they'll copy it for you.
#3 Posted : Tuesday, 29 March 2011 6:03:29 PM(UTC)
If it's a WB ute, these use the same controls as HJ-HZ.
The vacuum plumbing diagram in the HQ workshop manual (Vol 5) is the one you need.
As HK1837 has said, if you are using WB Statesman dash & controls then you need the WB parts manual.
