Bruvpig Offline
#1 Posted : Wednesday, 20 April 2011 9:56:14 PM(UTC)
Bruvpig
Anyone with a wreck in the backyard.......
I'm after a floor crossmember to replace the one that was cut to fit a 4speed on my panelvan. Its the one that the gearbox crossmember is bolted to.
I can replace the whole thing or just a section, & if there is a little of the tunnel still attached then all the better.
Brian
Stepping stone or stumbling block...your choice
ht307munro Offline
#2 Posted : Thursday, 21 April 2011 12:56:16 AM(UTC)
ht307munro
Where are u located? I have a couple of cars I am wrecking out but am in Central Queensland.
Alex
Bruvpig Offline
#3 Posted : Thursday, 21 April 2011 4:00:58 AM(UTC)
Bruvpig
In the ACT, but I can arrange a courier for pick up.
I'm going out to the shed tomorrow, so I'll get some pickies of the mess and hole so as to get an idea of the bit needed.
Brian
dirty davo Offline
#4 Posted : Thursday, 21 April 2011 4:25:31 AM(UTC)
dirty davo
Brian
i can supply whateva you need, whether its a section or whole cross brace?? just specify if HK or HT/G
also tunnel section (just give me min. measurement of what you need)
regards dave 0412109239
The HKTG Garage Offline
#5 Posted : Thursday, 21 April 2011 4:25:57 AM(UTC)
The HKTG Garage
Brian
I've got 3 or 4 I'm about to chop up in the next few days. Give me a call on 0409 691 119. I'm in Adelaide.
Bruvpig Offline
#6 Posted : Thursday, 21 April 2011 5:01:35 AM(UTC)
Bruvpig
Thanks guys!!.
I'll post the photos and measurements of the bits I need tomorrow if I'm near the 'puter.
It's for a HK panelvan if it makes a difference. (I know about the mounting holes for the crossmember)
Now if anyone has a panelvan...... the top tailgate catches... they look like a flattened wingnut... and the puzzle is complete.
Brian
Bruvpig Offline
#7 Posted : Saturday, 23 April 2011 9:41:53 PM(UTC)
Bruvpig
Hi guys.
About 250mm from the center of the hump each way, and 300mm from the back edge of the crossmember toward the firewall off of the tunnel is needed. The hole is on the top of the tunnel.
Give me an email with costs etc.
Many thanks for your replies.
Brian
Bruvpig Offline
#8 Posted : Saturday, 23 April 2011 9:46:36 PM(UTC)
Bruvpig
Hi guys.
Brian
