6pak Offline
#1 Posted : Friday, 1 April 2005 9:16:02 PM(UTC)
6pak
Hi Guys. I need to change from linkages to a cable operated throttle if i'm going to run my new Edelbrock manifold as the carb is offset meaning that the linkages will be at the wrong angle. Has anyone converted a ZD or XY to cable and what set up did you adapt. I haven't really had a chance to go to the wreckers and have a fossick with the tape measure but I did have a half arsed idea that an EA falcon pedal/cable assembly might work. Any suggestions?
#2 Posted : Wednesday, 6 April 2005 12:20:26 AM(UTC)
the EA falcon pedal/cable assembly is a good idea as lond as it fits to your carby.it may not be long enough,ED may fit bettr just get a pedal and cable from the wreckers and see how it will go. an XE/F pedal and XE V8 (coz its longer)would probably be th
6pak Offline
#3 Posted : Wednesday, 6 April 2005 9:27:22 AM(UTC)
6pak
Hi Chris. If you've already carried out this conversion using XE parts i think it would be a logical choice for me to follow the same path rather than trying to re-invent the wheel. Thanks for your input.
#4 Posted : Thursday, 7 April 2005 9:45:22 PM(UTC)
yer use the XE pedal and cable. the V8 XE cable may be hard 2 track down secondhand coz there wernt that may V8 XEs. im pretty sure you can buy them new. make sure its XE not XD coz they are different. the XE and XF pedals are exactly the same so are the
#5 Posted : Friday, 8 April 2005 1:19:48 AM(UTC)
So you live in Perth? if you need a hand let me know, i love ZD Fairlanes and would be happy to help.
#6 Posted : Friday, 8 April 2005 3:03:12 AM(UTC)
Originally posted by Chris 302
XE and XF pedals are exactly the same so are the 6 cylinder cables but i dont think the
#7 Posted : Saturday, 9 April 2005 12:43:23 AM(UTC)
no, because all of the V8 cables (XE cables) i have seen go around the front of the engine and turn around to operate the carby from the left side(passenger). on the EB-AU V8s (5liter windsors) the throttle is operated from the back left side , it dosent
#8 Posted : Saturday, 9 April 2005 12:43:26 AM(UTC)
#9 Posted : Wednesday, 13 April 2005 7:54:42 AM(UTC)
Yeah Chris is right all the V8 XE cables i have seen do go around the front of the engine and turn around to operate the carby from the left side
#10 Posted : Sunday, 1 May 2005 10:47:38 PM(UTC)
The XD pedal is an easy fit t the ZD - I have one in my ZC and one in my wife's XY
Ther is no hole for the cable to go through the firewall. but there is a dimple there where you have to drill the hole - same goes for two of the pedal assy mounting scr
6pak Offline
#11 Posted : Monday, 2 May 2005 12:39:59 AM(UTC)
6pak
Thanks ZC Cruiser. I'm very interested to have a look at any photo's you may have. My e-mail is [email protected]
ZC-Cruiser Offline
#12 Posted : Monday, 2 May 2005 1:59:38 AM(UTC)
ZC-Cruiser
I have a whole stack of pics of my ZC in various stages of conversion and upgrade here:
http://www.ftw.com.au/cp...dex.php?cat=53&Itemid=47
I'll have to get some detail shots of the pedal install for you - I'm not sure there are any in that lot
It's good to honk in a Henry
ZC-Cruiser Offline
#13 Posted : Monday, 2 May 2005 2:40:02 AM(UTC)
ZC-Cruiser
OK 6pak, detail pics sent to your email.
The part you want is definetly XD
XE and XF have a much smaller pedal assembly that simply won't work with the earlier model car - the cable would appear in the wheel arch instead of the engine bay...
I
6pak Offline
#14 Posted : Wednesday, 4 May 2005 10:11:57 AM(UTC)
6pak
Thanks ZC Cruiser. I'm definitely on the right track now! That's what i love about this site, There's always someone who's already tried stuff out before you and is willing to share the knowledge! Cheers :)
#15 Posted : Tuesday, 10 May 2005 4:57:01 AM(UTC)
hollo
#16 Posted : Thursday, 12 May 2005 8:36:12 AM(UTC)
depending on what carby you are useing but on the holleys i use an XD six cylinder cable and bring it in from the LH rear of carby. i have an XB with clevo and edelbrock performer. i have found the shorter cable fits better with the holley linkages and is
#17 Posted : Sunday, 29 May 2005 6:27:10 AM(UTC)
ANYONE HAVE ANY IDEAS ON HOOKING UP THE ACCELERATOR CABLE ON A 750 HOLLEY ON A WEIAND XCELLERATOR MANIFOLD WITH A 2INCH ALLOY SPACER IN A CLEVO NOTHING SEEMS TO LINE UP OR LOOK NEAT
