monman71 Offline
#1 Posted : Saturday, 18 June 2011 5:53:19 AM(UTC)
monman71
Hi All,did holden in the 70s when stamping engines and sub frames do it by heat?i am asking because if a number was grounded off and restamped i would be able to get the original numbers by the heat marks under the paint?Cheers
#2 Posted : Sunday, 19 June 2011 5:15:14 AM(UTC)
in the HQ-WB series the chassis numbers were stamped by a machine (rolled on)
i'm unsure about the engine numbers but i'd imagine they were done the same way
no heat was used
to find a number you can wave a oxy torch over the area and it'll (sometimes) show up briefly, this works really well on blocks that have been decked and the number was machined off
This page was generated in 0.016 seconds.
