iuiw Offline
#1 Posted : Wednesday, 6 July 2011 4:30:37 PM(UTC)
iuiw
My LJ has a shudder/vibration on idle, any ideas where to look? Also what hole does the push rod go through on the throwout lever (has two holes - inner or outer) on a aussie 4 speed. Car is running a rat trap. Where does the return spring go?
Help please
silverJ Offline
#2 Posted : Friday, 8 July 2011 10:27:54 PM(UTC)
silverJ
Had a look at mine & looks like the pushrod goes into
the outer hole, bit hard to see but the factory manual
looks like the outer hole too but check it for alignment
when its all assembled.
The return spring hooks into a hole in the RH outrigger
of the K frame
J
