Holden1Tonner Offline
#1 Posted : Monday, 1 August 2011 1:28:40 AM(UTC)
Holden1Tonner
G'day Gents,
I always had this problem that the gas cap of my HQ 1 Tonner leaks when driving around a corner or stopping. The seal on the gas cap was porous so I decided to get a new one. I thought that solved the problem but no, it's still leaking every time I stop or do a left turn.
Are these leaking through the key hole? What is wrong here, I can't imagine that this is 'normal' operation. Anyone every had similar issues?
I tried to get to work only doing right turns which sort of works since there are roundabouts all the way but would prefer to fix this.
"I killed the Bank"
Andrew Jackson, last words
#2 Posted : Monday, 1 August 2011 8:26:44 PM(UTC)
When I first read this post, I'm thinking 'if he has a gas leak, he should see a gas guy', but on re-reading it, I don't think he's talking LPG, he actually has a petrol cap leak.
It's probably leaking thru the key lock mechanism, this is common with aftermarket caps.
BIGCAV Offline
#3 Posted : Monday, 1 August 2011 9:27:00 PM(UTC)
BIGCAV
Hi Holden 1 Tonner
i would suggest you get in contact with CPC auto parts at http://cpcauto.com.au/ or http://cpcauto.com.au/contact.aspx
im guessing it is a CPC cap atleast, if you speak with them they may be able to sort out any issues
are you also certain its the correct cap? i think the listings get pretty complicated around hq and have seen countless times the wrong cap sold
just a thought
#4 Posted : Tuesday, 2 August 2011 12:11:14 AM(UTC)
Holden1Tonner
Thanks guys, yes it's the correct cap from CPC, but it took us a while to figure out which one is the correct one.
So I have to disassemble the thing and seal it with epoxy somehow.
"I killed the Bank"
74HJLS Offline
#5 Posted : Tuesday, 2 August 2011 10:51:07 PM(UTC)
74HJLS
Some may be vented
Pete.
