98lowlane Offline
#1 Posted : Monday, 22 August 2011 4:30:37 AM(UTC)
98lowlane
Hi guys, Im new to the forum
Ive got a 98 nl fairlane 4.0 litre, Prior to starting the car with acc turned on the oil pressure gauge light comes on and the needle reads zero. Is this somthing to worry about? as it never used to do. Also on idle the pressue goes up and down and with acceleration the pressure goes up? Is this normal? Im an apprentice and dont have much $ so any help would be much appreciated.
Thanks 98lowlane
BIGCAV Offline
#2 Posted : Monday, 22 August 2011 4:51:29 AM(UTC)
BIGCAV
sorry but i just got to make sure i read that right, your asking if its normal not to have oil pressure when the motors not running? if so of course its normal, the motors not running so of course the oil pump isnt moving
its normal for a warm motor to have a lower oil pressure when idling then when reving
xagtmick Offline
#3 Posted : Friday, 26 August 2011 9:35:13 AM(UTC)
xagtmick
its completly normal what you mentioned. i have a 97 NL 4.0 litre, does exactly the same thing. when the car is idling & the oil pressure light comes on & it beeps at ya is when ya start to worry, sort of
