#1 Posted : Friday, 2 September 2011 7:50:12 AM(UTC)
vr heater appears to be jammed on. just where is the under bonnet valve so i can turn it off manually or block it?
thanks
#2 Posted : Friday, 2 September 2011 8:08:42 AM(UTC)
On a V6, it's below the brake booster, just above the chassis rail, and has 4 hoses going into it.
You can't block it - the 4-way valve works to direct water through the core when open, and re-route it back through the motor when closed.
If the butterfly inside the valve is corroded away, then it will let the heater all the time, so maybe that could be your issue.
Mr Bob Dobalina Offline
#3 Posted : Friday, 2 September 2011 9:04:28 AM(UTC)
Mr Bob Dobalina
I think we should make a gentlemans agreement to refer to engines as 'engines' and only use 'motor' when we are talking about washing machines, heater motors, wiper motors etc.
peter_flane Offline
#4 Posted : Friday, 2 September 2011 9:57:37 AM(UTC)
peter_flane
In my opinion Bob, you are a moron.
What would you say if I said you are a moron?
#5 Posted : Friday, 2 September 2011 10:38:06 AM(UTC)
Mr Bob Dobalina
I'd say you're a bit of a try-hard with no real skills or imagination (or education). Why do you ask? Do you think that your opinion is especially valid (or of any importance to me) or that your sig which needs to be posted every time you comment makes you especially significant? What a man!
If anyone's a moron, Pete, you are way closer to fitting the bill.
#6 Posted : Saturday, 3 September 2011 10:14:25 AM(UTC)
dear bob . no.
for the record, a gentleman's agreement is an agreement between two people who are neither gentleman nor who intend to keep it.
Edited by user Saturday, 3 September 2011 10:17:10 AM(UTC)  | Reason: Not specified
#7 Posted : Saturday, 3 September 2011 10:15:34 AM(UTC)
mick, thanks for something constructive.
