sgo Offline
#1 Posted : Friday, 30 September 2011 6:01:33 AM(UTC)
sgo
Can someone advise me of how to find out the build date, and any other releted info on a ht/hg Monaro?
thanks.
80569K Offline
#2 Posted : Friday, 30 September 2011 7:55:59 AM(UTC)
80569K
As you look at it there will be a date code stamped on the bottom left of the steering box (assuming it's the original box), and if it's still there you will find a stencilled date code on the end of the steering column poking out of the firewall into the engine bay.
The date code on the box is day month & year, eg 12D9 means 12/4/69, you will have to check the archives to get all the codes. That date will be the day or very close to the assembly date.
sgo Offline
#3 Posted : Wednesday, 12 October 2011 4:00:55 AM(UTC)
sgo
Thanks, I found "3J9"
So I'm guessing 3rd. October 1969?
dirty davo Offline
#4 Posted : Wednesday, 12 October 2011 4:36:20 AM(UTC)
dirty davo
if it closely matches th date on ya big nut m/cyl & left front side of outrigger, ya pritty original
regards DD
mph61 Offline
#5 Posted : Wednesday, 12 October 2011 8:03:29 AM(UTC)
mph61
There was no letter I used so 3J9 would be 3rd sept 69 (I might be wrong)
sgo Offline
#6 Posted : Wednesday, 12 October 2011 6:42:39 PM(UTC)
sgo
Well the master cylinder has no big nut, just a cast housing. It's been that way since the early seventies.
The front-end/outrigger has just been painted, so I've lost that info.
cheers.
