colt Offline
#1 Posted : Saturday, 1 October 2011 10:09:27 PM(UTC)
colt
If you replace a V8 speedo with a V6 speedo will it read differently?
Colin.
#2 Posted : Sunday, 2 October 2011 1:22:11 AM(UTC)
No, but the tacho will.
#3 Posted : Sunday, 2 October 2011 9:04:04 AM(UTC)
actually the tacho won't work at all. the trip meter and odometer on my VR were not working and I was offered a dash out of a V8 the tacho did not register at all, the same guy had a v6 dash put that in worked perfectly.
colt Offline
#4 Posted : Tuesday, 4 October 2011 3:43:01 AM(UTC)
colt
That's my problem, the odometer & trip stopped working. I've pulled a replacement dash to bits so that I just use the speedo. I believe this is a common problem.
Colin.
#5 Posted : Tuesday, 4 October 2011 9:01:25 AM(UTC)
you should have said so there is a little plastic gear in the speedo that breaks a tooth and then the odo and trip won't work.
you can buy them off ebay for about 8 bucks and they are fiddly but easy to fit but took me about 5 attempts to get it to work as the gear seems to need to be aligned correctly, i was fitting it driving it no go unfit it refit it drive it eventually fluked the right way around and it works ok.
Edited by user Tuesday, 4 October 2011 9:03:20 AM(UTC)  | Reason: Not specified
#6 Posted : Wednesday, 5 October 2011 4:37:57 PM(UTC)
The tacho will work. The difference between the V8 & V6 tacho is the placement of a resistor on the main circuit board - changes it from reading 4 pulses per revolution to 3 (or vice-versa).
I've got pics somewhere of where I changed one over.
The other cluster difference is the temp gauge - V8 & V6 are slightly different in their calibration - you can pick the V8 one by the translucent green paint on the end of the 2 pins that secure it.
The reason you may not have got the tacho to work is that there are variations in the dash pins in the 3 sockets across the models. You really need to be careful swapping clusters over. If it's not like-for-like, then the least that will happen is something won't work, but the worst case (between VN & VR, or vice-versa - I can't remember now) you'll let the smoke out.
the Blue Light Offline
#7 Posted : Thursday, 6 October 2011 8:13:20 AM(UTC)
the Blue Light
So your saying that VN - VR electronics are smoke based?
#8 Posted : Thursday, 6 October 2011 4:11:52 PM(UTC)
All electronics are - the trick is to make sure the smoke stays inside all the little components on the circuit board, and then it still works :)
