toddyg Offline
#1 Posted : Tuesday, 4 October 2011 7:13:35 AM(UTC)
toddyg
what drama's do i need to fiqure out if i fit vn heads to
my 308 hq coupe.will my current power steer and alternator brackets
fit ,will my elderbrok torker manifold need to be changed,and would some of the electrical harness need to be re worked
JBM Offline
#2 Posted : Tuesday, 4 October 2011 11:14:15 AM(UTC)
JBM
Youll need a new inlet manifold, exhaust manifold/extractors and cam.
If you use a 4 barrel manifold, such as a Harrop type, you can use a carby and avoid the EFI electronic setup.
Accessories could remain the same, otherwise you would need a serpentine belt balancer, power steer pump, alternator pulley and tensioner.
Its been done plenty of times so there should be some good info in cyberspace. You could also try the Street Commodores forum.
James
