dirty davo Offline
#1 Posted : Wednesday, 9 November 2011 6:24:03 AM(UTC)
dirty davo
i have found a hk wagon from NZ with only 1 tag & no firewall number.
is similar to AUS but bit different so tryin to break it down
803358N705690
it is an early 68 as has early grey seat trim but oval, not round st/wheel so my guess is mid 1968
'80335'-obviously kingswood wagon
'8' - 1968
N7 - NZ plant
05690 - 5960th hk body
can anyone confirm this???
does anyone else have any info on NZ compliance or tag/s
regards DD
justgm Offline
#2 Posted : Wednesday, 9 November 2011 6:18:42 PM(UTC)
justgm
YES THIS IS CORRECT FOR NZ , NO FIREWALL STAMPING ( OR EVEN CHASSI STAMPING ON HQ ) I HAVE A FEW SINGLE GMNZ TAGS EG ; FE UTE STAMPED 18 , STAMPING WAS QUITE OFTEN VERY POORLY DONE ! I HAVE NOT BEEN ABLE TO FIND OUT HOW THE GMNZ NUMBERING SYSTEM WORKED , I AM WORKING ON IT . MARK.
dirty davo Offline
#3 Posted : Wednesday, 9 November 2011 7:29:32 PM(UTC)
dirty davo
post one up or PM me. going on th one i posted up,they seem to be similar to AUS so not too hard to decifer
regards DD
#4 Posted : Wednesday, 9 November 2011 10:29:04 PM(UTC)
Davo, it won't be the 5690th HK body, that is the plant sequence number just like in the Australian plants. It is the total number of vehicle issued with a PSN at that assembly plant since the VIN system started in late 1967 so will include whatever else they assembled there too.
justgm Offline
#5 Posted : Wednesday, 9 November 2011 11:19:10 PM(UTC)
justgm
YES THAT SOUNDS CORRECT , ALL SORTS OF STUFF WAS BEING ASSEMBLED THEN . I AM TRYING TO WORK OUT WHY THESE 2 GMNZ COMMODORE'S THAT SHOULD BE CLOSE IN BUILD DATES ( I BELEIVE THEY WERE BUILT IN A BATCH OF 30 ? ) 6S69LCZ738084H & 6S69LDZ74111H HAVE SUCH DIFFERENT NUMBERS , MAYBE THE 1ST OF SEPT CHANGEOVER FINISHES @ 38---- & STARTS AT 40000 ???? IF SO MIGHT APPLY TO ALL EARLY BUILDS AS WELL ? MARK.
