nhawtin Offline
#1 Posted : Saturday, 3 December 2011 5:01:05 AM(UTC)
nhawtin
Hey guys. Just a quick note. My neighbor has a ef 1994 Gil six. It seems to be hunting at idle. The car runs fine but when she comes to a intersection it stalls. The car iS on gas but has un even idle on petrol too. Can anyone shed some light. She is a single mum and cant really afford to keep going to mechanics. I'm trying to help her out but I'm not up on these cars. I thought mayb vacuum leak??
Your knowledge and pointers would be appreciated greatly.
Nick
#2 Posted : Saturday, 3 December 2011 9:27:45 AM(UTC)
Could be a vacuum leak. It could also be the map sensor on the other hand it could just be that the IAC and/or throttle body needs a clean.
If you give it a rev in neutral does it drop way below idle, almost stall and then settle into an idle when you lift the foot?
Bruvpig Offline
#3 Posted : Saturday, 3 December 2011 11:03:19 AM(UTC)
Bruvpig
Try the idle stepper motor, it fixed mine on gas with the same problem.
This is what it looks like:
http://www.ebay.com.au/i...ries&hash=item3cbeede414
Sits on top of the throttle body and is an easy repair, about 5 min.
Stepping stone or stumbling block...your choice
#4 Posted : Sunday, 4 December 2011 1:37:38 AM(UTC)
Yep that's the IAC. Cheaper to try and clean the IAC with a $10 can of carby cleaner before replacing it. The air ducts in them can block with crud.
