Bowtie383 Offline
#1 Posted : Monday, 12 December 2011 4:04:19 AM(UTC)
Bowtie383
Guys, I just wan't to find out if the 10 bolt for the models I mentioned on the heading are all the same width from flange to flange including statesman and 1 tonners.
Also can someone give me a mesurement of one please I would be grateful if someone could.
Regards Tony.
What goes around comes around
#2 Posted : Monday, 12 December 2011 7:11:08 AM(UTC)
No. HZ and WB disc brake diffs are narrower. Housings are the same but axles sit in a little further so that when discs are put on the overall width is the same as a drum brake diff with drums on. All drum brake diffs are the same width.
Bowtie383 Offline
#3 Posted : Monday, 12 December 2011 7:36:38 AM(UTC)
Bowtie383
Thanks for answering my question mate as I do wan't to put a disc brake rear end under my Monaro as I don't need the 9 inch anymore.
Regards Tony.
Edited by user Monday, 12 December 2011 7:38:15 AM(UTC)  | Reason: Not specified
#4 Posted : Monday, 12 December 2011 8:04:58 PM(UTC)
Axles on disc brake diffs also have a smaller diameter flange so the disc fits over it. Wheel studs are longer too.
Bowtie383 Offline
#5 Posted : Tuesday, 13 December 2011 1:47:03 AM(UTC)
Bowtie383
Just a question on the wheel studs been longer,I have just bought a set of 15inc Pontiac Ralley11 rims and I want to use the reproduction wheel nuts they used on the GTS so will they still do up all the way to the rim?
Regards Tony
#6 Posted : Tuesday, 13 December 2011 2:37:55 AM(UTC)
The studs are longer to cater for the thicker disc mounting.
The amount they protrude beyond the disc (to accept the wheel rim) is the same as drum brake cars.
Bowtie383 Offline
#7 Posted : Tuesday, 13 December 2011 2:53:26 AM(UTC)
Bowtie383
Thnaks Byron and Terry for all the advice guys.
Regards Tony.
