BREDBO Offline
#1 Posted : Tuesday, 13 December 2011 7:13:12 AM(UTC)
BREDBO
I just had the first drive of the car and the brake pedal is hard as there seems to be no power assistance.Car is HT holden with HQ front discs VB commodore rear disc,HT v8 power booster and master cylinder.Original brake lines with no proportioning valve.Vacume line feeds from the manifold as normal.Brake pedal doesn,t move slightly when you start the car.what could be the problem?
#2 Posted : Wednesday, 14 December 2011 3:33:17 AM(UTC)
Is it a 4 wheel disc brake master cylinder? If not you'll have to modify the rear circuit to make it operate rear discs.
BREDBO Offline
#3 Posted : Wednesday, 14 December 2011 7:24:37 AM(UTC)
BREDBO
Disc/drum HQ mastercylinder brand new.Vaccumn line has vacumn,rear discs operate when pedal pressed.
#4 Posted : Thursday, 15 December 2011 3:35:18 AM(UTC)
You need to modify the rear output of the master cylinder to operate discs. This involves removing the check valve from the master cylinder in the outlet of the master for the rear circuit.
BREDBO Offline
#5 Posted : Thursday, 15 December 2011 7:59:44 AM(UTC)
BREDBO
How do I get to the check valve.Remove circlip and disassemble piston or is it at the outlet where the brake line exits from the master cylinder or at the junction box under the guard?
#6 Posted : Thursday, 15 December 2011 4:40:09 PM(UTC)
Outlet, you'll see it. I just screw a self tapper into it and rip it out with multigrips. I'd talk to a brake specialist first to understand what/why/how etc.
BREDBO Offline
#7 Posted : Friday, 16 December 2011 7:05:58 PM(UTC)
BREDBO
Thanks for that HK1837 much appeciated.
BREDBO Offline
#8 Posted : Saturday, 7 January 2012 11:41:53 AM(UTC)
BREDBO
Have removed check valve from master cylinder and still have what appears to be no power assistance.Pedal pressure to stop whether engine running or not appears pretty much the same. Is there a rebuild kit for the ht booster and is it a diy project or a job for the professionals?
AMunro327 Offline
#9 Posted : Saturday, 7 January 2012 6:06:08 PM(UTC)
AMunro327
In my opinion, it's a job for the pro's. Some brake places have a way of setting them up on a test bench and testing them without pulling them apart. Might be best to do this first.
