The HKTG Garage Offline
#1 Posted : Friday, 16 December 2011 10:14:35 PM(UTC)
The HKTG Garage
I am hoping that someone can help me work out an approximate (month) build date for a friends HK GTS 327.
Adelaide built 81837 Body No.: 2xxA (Less 215, more than 200)
First registered in Dandenong Victoria 19th August 1969
Reg Plate: KJO-6xx
Firewall Body Number: 48,7xx A
Engine No.: 32776xxx K11xxH
81837KL1253XX
Any help is much appreciated. I'm not looking for exact day but if I can get it down to month of build would be fine.
mph61 Offline
#2 Posted : Friday, 16 December 2011 10:52:00 PM(UTC)
mph61
The usual places to find dates are steering box, left side front out rigger, under heater box, on back of speedo/gauges I also found a date of some sort written under my dash pad this was all on a HK I dont know if it is standard with all models hope this helps
#3 Posted : Saturday, 17 December 2011 12:22:45 AM(UTC)
The HKTG Garage
Yes, this I know. These are the parts that have been changed over the years and the whole reason for the post so I can locate them. It's a classic 80's molestation. Everything wrong. BUT, the tags hadnt been removed and we have the accompanying paperwork.
#4 Posted : Saturday, 17 December 2011 1:25:05 AM(UTC)
Simon
Pass the numbers through to me and i'll get Ben to tell you an approx date. It is a pretty late example though.
#5 Posted : Saturday, 17 December 2011 6:04:18 AM(UTC)
3/69
