zl296 Offline
#1 Posted : Wednesday, 4 January 2012 9:29:37 AM(UTC)
zl296
will,a hd,column drop straight into a ej,& wiring....
Utility8 Offline
#2 Posted : Thursday, 5 January 2012 1:38:54 AM(UTC)
Utility8
Yes, EJ to HR manual columns are the same.
utility8
#3 Posted : Thursday, 5 January 2012 2:22:01 AM(UTC)
To add to that, there are some minor differences. They will all bolt in, but if you want to retain your column shift, it will matter if it's from an auto or a manual. If yours is an auto, EJ/EH autos have a different inhibitor switch & indicator quadrant to the HD/HR.
Also EJ boxes have a 14:1 ratio, whereas the EH/HD/HR have a 16:1 ratio, meaning if you fit an EJ box to a later series, it will make the steering slightly quicker (more direct) but heavier.
