lildog Offline
#1 Posted : Wednesday, 25 January 2012 2:15:15 AM(UTC)
lildog
Will a HZ GTS dash fit into a WB?
#2 Posted : Wednesday, 25 January 2012 2:22:17 AM(UTC)
The GTS instrument cluster is a direct fit into the WB commercial range because the dash is the same, but I think into a WB DeVille or Caprice would be a bit of a challenge.
#3 Posted : Wednesday, 25 January 2012 3:33:06 AM(UTC)
Full instrument dash was actually optional in WB commercials, and it is the same as HZ.
Terry, I'm pretty sure it is a straight bolt into WB Statesman too, just have to remove the glovebox bracket. The reverse is easily done, ie WB Statesman dash into HJ-HZ, just have to add the glovebox bracket.
mackv8 Offline
#4 Posted : Monday, 30 January 2012 12:51:31 AM(UTC)
mackv8
HZ loom is differant to WB loom in the plugs.
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
