pete11 Offline
#1 Posted : Thursday, 26 January 2012 2:16:02 AM(UTC)
pete11
hi all.i have a hg belmont wagon with a 161 3 on the tree and drum brakes all round.the car is in a pretty tired state and im researching the ins and outs of fitting a v6 from a vn s2 or vp commodore. unsure whether to go manual or auto at this stage.the questions i have for now are can i use the front vn/vp discs,calipers and brake booster? ive read that i can use the commy diff with the hg mount brackets welded to it,is this correct?if i went with an auto would i need an auto pedal box from a hg?use the commy one?or use the one i have and remove the clutch pedal?
I will be buying a complete vn/vp donor car and a v6 conversion kit.
Are there any preferences which kits to buy ie:pat gardner or castlemain?
#2 Posted : Thursday, 26 January 2012 3:05:54 AM(UTC)
Firstly, i'd buy a VN-VP V8. Much easier conversion, and you won't have to Engineer it if you do it right. V6 won't fit properly transmission wise, and will reauire floor surgery. V8 will fit if you use a TH350.
Utility8 Offline
#3 Posted : Thursday, 26 January 2012 5:13:02 AM(UTC)
Utility8
Agree 100% & will sound a whole lot better.
utility8
pete11 Offline
#4 Posted : Thursday, 26 January 2012 5:47:40 AM(UTC)
pete11
cheers for the replies so far.i like the idea of an old simple non electronic v8 (had a hj 5litre wagon years ago and liked the lazy power,ease of maintenance and the exhaust note)but they and the parts i would require seem to be hard to find and pricey.as for trying to find a vn/vp commodore v8 people seem to want silly prices for them here in wa.should be able to pick up a v6 donor car for around $500.
i still need to contact the wa dept of transport re what i can do before i need an engineers certificate.
peter_flane Offline
#5 Posted : Thursday, 26 January 2012 5:47:44 AM(UTC)
peter_flane
The HG had a cast iron block 308 from factory.
Get a pre '76 308 block and TH350 transmission, add all associated 308 brakes and suspension. Your car is able to be legally registered as a 308, as long as you add all of the 308 bits from another 308 HG.
Then if you want, put VN-VP heads, fuel injection etc on the block. You can end up with an easy 300hp all day any day reliably and fuel efficient (sort of efficient).
The V6 will be less power by far, and end up costing just as much, if not more to do.
#6 Posted : Thursday, 26 January 2012 5:59:28 AM(UTC)
^^That's what I was getting at. Use an early red 308, and put a VN-VP top end on it. You don't necessarily need a whole car, just a complete engine to suit rebuild will do you. You'll have to buy a new cam but that is about all you need as far as the engine is concerned. The rest is external stuff. Send me a PM and i'll send you some info.
greenhj Offline
#7 Posted : Thursday, 26 January 2012 7:07:11 AM(UTC)
greenhj
for the kinds of dollars a somewhat decent HV8 will cost, its probably cheaper to buy a crate SBC.
#8 Posted : Thursday, 26 January 2012 6:47:13 PM(UTC)
my local mechanic has a HT prem he fitted it with a VN V6 auto says it goes pretty good and its his daily driver.
928S Offline
#9 Posted : Friday, 27 January 2012 1:02:54 AM(UTC)
928S
Myself I wouldn't use the VN V6 because of the bottom end oiling, the rod bearings have to be kept an eye on as they suffer quicker wear than one would like. I personally like the idea of a V6 in these cars, it may not be the smartest choice money wise, I think the fellow who said add a fuel injected V8 308 is probably on the money for the best bang for buck. Later model ecotec engines had the oiling fault rectified, I also think the compression is way too low for any decent performance.
pete11 Offline
#10 Posted : Friday, 27 January 2012 11:20:00 PM(UTC)
pete11
is that the vn series 1 engine or all the v6,s up to the ecotec.i was under the impression the v6 was fairly robust and that most problems are electrical eg fuel pumps,crank angle sensors etc.thats a big reason i initially looked into going with an old v8 with none of the electronic wizardry(well that and the sound).trying to find an old v8,gearbox,diff,brakes in wa to fit into the hg,at a reaonable price is the hard part.figure buying a vn vp donor car for a few hundred bucks and fitting everything i can from that into the belmont would be a good option.im not after a high performance car (i have a motorbike for that)just a nice reliable cruiser with more power than an inline 6 that will also tow a trailer with ease when i need to.
928S Offline
#11 Posted : Saturday, 28 January 2012 1:41:52 AM(UTC)
928S
Pete good question, I just asked a friend, he said he was sure the V R didn't have the problem, can't be sure exactly when it was sorted. Sorry can't help anymore but maybe ask over at just commodores. I must admit I have been considering options to just get the holden inline six going stronger. Good luck with your project.
pete11 Offline
#12 Posted : Tuesday, 31 January 2012 11:37:12 PM(UTC)
pete11
still trying to find answers to my original questions.anyone?
Jonesy77 Offline
#13 Posted : Wednesday, 1 February 2012 6:31:09 AM(UTC)
Jonesy77
G'day pete11 I have seen them for sale at Castlemain rod shop they have kits for this type of thing and rod hadfield has been in the game for a long time,but he has sold the business a while ago and the new guy is pritty good they can help with the brakes,if you need a different boster crossmembers for auto and manual boxes, The diff i'm not to sure if they are the same widths or not if the size is close you should be able to cut of the old brackets and weld the new ones on,I have fitted a VB commi diff to a kingswood ute but i placed 10' wide deep dish rims on and a modified tailshaft and your pedal box i don't think you need to change but not 100% sure and the sump you can get as well also the v6 set up would be shorter than a v8 and you may be able to move the engine forward or backward to minimalise how much you have to cut the trans hump
cheers steve
Happiness is not a destination but a way of life (so drive a kingswood)
