The HKTG Garage Offline
#1 Posted : Monday, 27 February 2012 8:45:08 AM(UTC)
The HKTG Garage
Does anybody know if it's inevitable that a fibre timing gear on a 186 red motor will disintegrate during the life of the motor? Have they been known to not go at all?
Some say that no matter what, in its running life, without any word of warning, it will break down.
My belief is that when a motor has had little or unregular use, the fibre gear dries out somewhat as opposed to an engine that is maintained and used regularly.
Sebring Orange Offline
#2 Posted : Monday, 27 February 2012 9:13:52 AM(UTC)
Sebring Orange
I have owned quite a few HKTGs and driven them to work and back and normal use and 3 have go on me at not such a high mileage either .
I know many other people have had a few go on them also in regular use .
In a Holden dealership my father use to work in they were known for never making it much past 120,000Kms in Early commodores either .
#3 Posted : Monday, 27 February 2012 9:29:32 AM(UTC)
I don't think usage pattern has any effect - in the 90s my daily driven ones went just as early as the grandpa cars I've bought over the years. Come to think of it, I never had a Commodore 3.3L that didn't strip it (unless I got to it first with an alloy replacement).
69 rust bucket Offline
#4 Posted : Monday, 27 February 2012 9:14:27 PM(UTC)
69 rust bucket
there is a cheap new old stock one on ebay for $10 at the moment if you need one
why drink & drive when you can drift & slide
AMunro327 Offline
#5 Posted : Monday, 27 February 2012 9:31:59 PM(UTC)
AMunro327
I had one chew out on a 202 HZ a while ago, and I mean chewed. About 3 or 4 teeth were gone. Drained the4 oil and a lot of fibre came out. Replaced the gear, got it going again, but the fibre must have gone through the oil galleries. Good oil pressure buy little oil flow. The result was not a pretty sight.
#6 Posted : Tuesday, 28 February 2012 3:05:51 AM(UTC)
i've had 2 go, both were in daily drivers
#7 Posted : Sunday, 11 March 2012 11:30:08 PM(UTC)
The HKTG Garage
I have got approximately 200,000 miles from my original bore untouched 186 out of a HT. It has been my daily driver engine for over 15 years now. I have done heavy towing work with it too.
