wayne hj owner Offline
#1 Posted : Thursday, 15 March 2012 4:36:38 AM(UTC)
wayne hj owner
just had auto rebuilt in hj wagon the car has a 202 elec/dizzy but lacks power to get up hills any suggestions.
thanks wayne
greenhj Offline
#2 Posted : Thursday, 15 March 2012 4:45:37 AM(UTC)
greenhj
The obvious answer is the finely tuned machine that gmh built is too gutless, being the engine, but ill instead ask if teh gearbox is kicking down properly when you get on the loud pedal?
#3 Posted : Thursday, 15 March 2012 5:02:17 AM(UTC)
wayne hj owner
kicking back down is fine
wayne
greenhj Offline
#4 Posted : Thursday, 15 March 2012 5:50:06 AM(UTC)
greenhj
ok, are the shift points the same as before?
torque convertor hasnt been changed/altered or otherwise molested?
i cant think of much else that a transmission would do that causes the engine to lose performance, so thats all i got :)
#5 Posted : Thursday, 15 March 2012 4:22:48 PM(UTC)
Low on fluid?
#6 Posted : Thursday, 15 March 2012 11:52:00 PM(UTC)
wayne hj owner
i am thinking it an engine problem rather than auto.
wayne
#7 Posted : Thursday, 15 March 2012 11:54:35 PM(UTC)
Get a pro to check it out.
The fault(s) could be many & varied, electrical , carby, mechanical or a combination of the all three.
Mr Sir Offline
#8 Posted : Sunday, 18 March 2012 4:13:02 AM(UTC)
Mr Sir
When did you last change the air cleaner?
jabba Offline
#9 Posted : Wednesday, 21 March 2012 1:31:51 AM(UTC)
jabba
With HEI, open the plugs up a bit compared to std points ignition. MY HJ (350, HEI) felt sluggish and ran rough. Opened plugs up from standard 35thou to 60thou - new car. Ran heaps better, uses less fuel.
Also, try advancing the ignition a couple of degrees at a time. Should notice the performance improve as the timing is advanced, until you start to get detonation under load / acceleration. Then back it back a degree at a time until you get the balance of power vs. ping
