CrustyHK Offline
#1 Posted : Tuesday, 20 March 2012 5:54:53 AM(UTC)
CrustyHK
Hey guys
Has anyone got any clues on fitting prem/brougham wheel trims to 6in rims?
Pete
The HKTG Garage Offline
#2 Posted : Tuesday, 20 March 2012 7:52:51 AM(UTC)
The HKTG Garage
They weren't available on them. When 6" rim was optioned they had sports wheel discs fitted. I've seen it done. If you bend all the spokes forward you may get it to fit.
dirty davo Offline
#3 Posted : Tuesday, 20 March 2012 6:13:04 PM(UTC)
dirty davo
broughams were optioned with 6" rims. i have a build sheet here to prove it.(wheels '6"', wheel trims 'frost')
cant picture monaro caps on a brougham.. that would be YUKK
regards DD
#4 Posted : Tuesday, 20 March 2012 9:33:22 PM(UTC)
Dave
Are you certain you have seen N66 (rally) wheels on a Brougham? I know they all have the wide wheel brackets but these are for the tyres I thought.
HG Brougham didn't have N66 available on Brougham (or at least you couldn't order them) as there was only 1 x tyre available. I don't have HK or HT here in front of me but I thought they were the same.
Pete, as Simon says if N66 Rally rims were optioned on Premier, PO2 wheel trim discs were mandatory (and not available on Brougham - as Dave says: yuk!). PO2 are the GTS caps.
CrustyHK Offline
#5 Posted : Wednesday, 21 March 2012 3:41:53 AM(UTC)
CrustyHK
Yeah the monaro trims look very ordinary on anything else.
The prem trims look really nice on the wider wheel but of course just keep falling off.
CrustyHK Offline
#6 Posted : Saturday, 24 March 2012 7:14:48 AM(UTC)
CrustyHK
Does anyone happen to have a monaro trim and a prem trim they can compare?
Does it look like the part of the monaro trim that grips the wheel could be addapted to the prem trim?
Pete
