tikaz Offline
#1 Posted : Wednesday, 9 May 2012 7:50:18 AM(UTC)
tikaz
just wondering if a hz kingswood sedan front end {bumber grill lights etc.] will fit a wb kingswood ute??
#2 Posted : Wednesday, 9 May 2012 5:30:01 PM(UTC)
Yes it will, but only 2 of the 3 bumper bar bolts on each side will fit. Use the WB inner guards too so you can keep the overflow bottle and canister where they are. You can use either the WB bonnet or the HZ bonnet, whichever is better. You'll have to much around with the harness a bit to get the lights to hook up. The best way to do it is also to open up the HZ's radiator support opening and unpick the radiator brackets off the WB support, then tack them onto the HZ's support. This way tou get to keep a superior cooling system. Takes a bit of work in unpicking spot welds but worth it in the end. Compare them side by side and you'll see what I mean.
Watch out for WB's with metric threads on the body bolts too and also the inner guard attaching screws ie use the right bolt and screw for the thread.
peter_flane Offline
#3 Posted : Thursday, 10 May 2012 7:21:22 AM(UTC)
peter_flane
Are you replacing the front guards too? They are different.
tikaz Offline
#4 Posted : Thursday, 10 May 2012 4:41:22 PM(UTC)
tikaz
Na not the gaurds just bumpers and grill and lights...shouldnt have too replace the radiator bracket should i?
#5 Posted : Thursday, 10 May 2012 5:50:35 PM(UTC)
As HK1837 has said, the guards are different they must be changed also. The radiator support panel should be also changed, along with the radiator & hoses.
There would be a lot of stuffing around to fit the WB grille & headlights to an HZ radiator support.
To summarise:- to fit a WB grille & headlights to an HZ, you will need change every panel forward of the firewall except for the bonnet. Plus radiator, shroud & hoses.
This page was generated in 0.083 seconds.
