Squeak327 Offline
#1 Posted : Thursday, 31 May 2012 1:18:40 AM(UTC)
Squeak327
Could someone please advise if there is a technically correct position for the over-riders on a HK T G.
I can't find the answer in any of the manuals I've got and based on the photos I have from various shows, there is a lack of consistency in their placement, particularly it seems, for the rears.
A reprint of a Holden Accessories Brochure in a book I have suggests the following position is correct for the front:
The Brochure does not show a rear fitment. The majority of the photos I have from shows etc suggest they should go here:
But having said that I have seen plenty mounted dead centre of the bumper mounting bolts and others mounted so they cover up the inner bolts.
#2 Posted : Thursday, 31 May 2012 1:54:49 AM(UTC)
Although I don't have a copy, I would think that the fitting instructions that come packed with the over-rider accessory kit would show some dimensions.
brou308 Offline
#3 Posted : Thursday, 31 May 2012 5:37:39 AM(UTC)
brou308
Hi The front over riders were fitted 13 inches from centre line of car to each over rider and the rears are fitted 14.5 inches from centre line of car to each over rider going by the copy of the fitting insructions i found on the net a couple of years back Cheers
Squeak327 Offline
#4 Posted : Thursday, 31 May 2012 7:18:16 AM(UTC)
Squeak327
Thanks fellas
dirty davo Offline
#5 Posted : Thursday, 31 May 2012 8:12:46 AM(UTC)
dirty davo
bit late i know, but brou308 is correct. 13" for fronts & 14.5" on rears. reason rears are wider is coz on a wagon, th t/gate would touch em if same as fronts.
The HKTG Garage Offline
#6 Posted : Thursday, 31 May 2012 6:08:51 PM(UTC)
The HKTG Garage
I have the original fitting instructions. Email me at [email protected] and i will send it to you free of charge.
Edited by user Thursday, 31 May 2012 6:11:26 PM(UTC)  | Reason: Not specified
Squeak327 Offline
#7 Posted : Thursday, 31 May 2012 8:02:42 PM(UTC)
Squeak327
Again, thanks all for the info and thanks Simon for the generous offer.
Yet another example of the value of this forum. Appreciate it
