52abel Offline
#1 Posted : Saturday, 16 June 2012 12:20:39 AM(UTC)
52abel
Hi all
Is there and easy way to change the bushes on a VS Commodore "Z" bar
Andy
#2 Posted : Monday, 18 June 2012 6:55:10 AM(UTC)
The ones in the control arm need to be pressed out.
The ones in the crossmember can be replaced with 2-pc ones at home easily enough.
You need to cut away some of the exposed rubber at the front face you can see (on the front of the K-frame outrigger). I use a hacksaw & utility knife. You don't have to cut it all out - just slice segments off around the perimeter. Once you have removed a good 5-10mm from the outer diameter, thump the centre with a hammer, and the bush will usually pop through.
